Viz Engine
BlueFish444 SD Lite Pro Express
Viz supports the SD Lite Pro Express card, and the more recent BlueFish444 cards.
BlueFish444 SD Lite Pro Express provides Fill, Key and GenLock connectors, and is the successor of the BlueFish444 Iridium|SD and the Digital Voodoo DeepBlue LT, that are no longer officially supported.
The card was mostly used with Viz Trio NV which basically was a system with the ability to run a Viz Trio client with local preview and video output on a single machine; hence, there was no video input or video playback support as with the Matrox X.mio Series. The local preview was able to render a different scene than the one being output on video. The card was typically seen on HP xw4600 workstations.
Connectors
Driver Installation
Connectors
The BNC connectors from left to right are:
SDI Out A (Fill): SDI 4:2:2/4:4:4/Video
SDI Out B (Key): SDI 4:2:2/4:4:4/Video
Ref In: Analog GenLock input
Driver Installation
Use the driver version available on Vizrt’s FTP server to make sure of correct functionality and ring buffer support.
Viz Artist/Engine Version |
Driver |
3.6.3 |
Bluefish444 v5.10.2.18 |
3.6.1 |
Bluefish444 v5.10.2.4 |
3.5.1 |
Bluefish444 v5.10.1.11 |
3.5 |
Bluefish444 v5.9.0.78 |
3.2.7 |
Bluefish444 v5.9.0.25 |
3.2.2 |
Bluefish444 v5.7.6 |
Note: Viz Engine 3.2.7 and 3.3.0 require the Bluefish444 v5.9.0.25 driver for all Digital Voodoo / Bluefish cards.
