MOS Object with Clip Templates Merged in a Mosart Template
A single MOS object is created for all Mosart templates of type PACKAGE or VOICEOVER from the default template set. In this example:
  • <mosExternalMetadata> node contains the list of variants for the Mosart templates of type PACKAGE and VOICEOVER.
  • <objID> of the MOS object is set to 25, representing a Mosart item type CLIP.
  • <objGroup> is the default template set name.
  • <type> node has name and category set to “CLIP”, and templateset set to the name of the default template set.
  • The variant for each template is built using some prefixes:
    1) for PACKAGE, the variant is set to MAZ-<template variant>
    2) for VOICEOVER, the variant is set to OFFMAZ-<template variant>
Note: When GroupByType is false, no MOS object will be sent for templates of type PACKAGE and VOICEOVER.
<mosObj>
<objID>LOWERTHIRDS</objID>
<objSlug>LOWERTHIRDS</objSlug>
<mosAbstract />
<objGroup>TEMPLATES</objGroup>
<objType>STILL</objType>
<objTB>50</objTB>
<objRev>1</objRev>
<objDur>0</objDur>
<!-- The status of the MOS object can be NEW, UPDATED or DELETED -->
<status>NEW</status>
<objAir>NOT READY</objAir>
<createdBy/>
<created/>
<changedBy/>
<changed/>
<description />
<mosScope>PLAYLIST</mosScope>
<mosSchema>http://www.mosartmedialab.no/schema/mositem.dtd</mosSchema>
<mosPayload>
<mosarttemplate>
<type name="LOWERTHIRDS" category="GRAPHICS">
<variants fieldtype="LIST" value="AUTOOUT">
<variant name="AUTOOUT">
<fields>
<field name="graphics_description" fieldtype="TEXT" />
<field name="graphics_id" fieldtype="TEXT" />
<field name="tc_in" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00"/>
<field name="tc_out" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00"/>
<field name="channel" value="DSK" fieldtype="LIST" keylist="channels" />
<field name="take" value="AUTO" fieldtype="LIST" keylist="taketypes" />
</fields>
</variant>
<variant name="KEEPWHILEBACKGROUND">
<fields>
<field name="tc_in" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00" />
<field name="tc_out" fieldtype="TIMECODE" inputmask="mm:ss" default="00:00" />
</fields>
</variant>
<variant name="KEEPWHILESTORY">
<fields>
</fields>
</variant>
<variant name="NONEAUTOOUT">
<fields>
</fields>
</variant>
</variants>
<!-- List of active channels (graphics destinations) as configured in OverlayGraphics Interface-->
<keys name="channels">
<k>WALL_2</k>
<k>WALL</k>
<k>TABLE</k>
<k>DSK</k>
</keys>
<keys name="taketypes">
<k>AUTO</k>
<k>MANUAL</k>
</keys>
</type>
</mosarttemplate>
</mosPayload>
</mosExternalMetadata>
</mosObj>
The list of channels contains the active destinations (destinations linked to a graphic engine) as configured in the Overlay Graphics interface.
For details of configuration, refer to section xxx.
