Version 3.6 | Published December 10, 2021 ©
Log and Report
  • A general GH ImEx Agent related log can be viewed under Report > Logs.
  • You configure the log level under Options > Configuration.
  • Furthermore, you can download an archive of all log and configuration files from Report > Export. This is particularly useful when troubleshooting and for support requests.
To View ImEx Agent Logs
  1. Navigate to Report > Logs to display the logs section.
  2. Search with custom text using the text field in the top right hand corner.
    images/download/attachments/57236807/dp06.png
To Manage Reports
  1. Navigate to Report > Export.
  2. The Export section displays all previously created report exports.
    images/download/attachments/57236807/report01.png
  3. Select one or multiple exports
  4. Click Download to download a .zip file containing information about ImEx Agent settings and current configuration.
    images/download/attachments/57236807/report02.png
Note: The report archives are stored in a temporary directory of the operating system, not persistent, and are lost when you stop or restart the ImEx Agent service.
To Create a Report
Click Create (1) to immediately generate an report export. The newly generated report is added to the list (2).
images/download/attachments/57236807/report03.png
