Version 3.6 | Published December 10, 2021 ©
Locate Duplicate Files
When files are copied from one folder to another, such as when creating linked or duplicate files, the copy exists as a duplicate of the original file. As long as neither the original file nor the copy is modified, they remain duplicates, since the checksum of both objects is the same.
Tip: The files can be renamed, and still remain duplicates.
To Locate Duplicates in a Graphic Hub
  1. Click View > Duplicates, or press CTRL + N, or CTRL + F5. The duplicates window is shown.
    images/download/attachments/85908466/image2021-11-29_8-48-17.png
    The duplicates window lists all the duplicates in the selected server, sorted by the names of the files. If duplicates carry different names, this is also shown.
  2. Right-click a duplicate for more information about it. This will open a menu with the following options:
    • Open Containing Folder in Explorer: Jumps to the folder in the Servers and Folders, where the selected file is placed.
    • Properties: Opens the File Properties window, which shows detailed information about the selected file.
