Version 3.6 | Published December 10, 2021 ©
Change Graphic Hub Server
You can change the binding between the Graphic Hub REST and Graphic Hub server.
  1. Navigate to Configuration > Change Graphic Hub server.
    images/download/attachments/81472547/ChangeGHServer.png
  2. Select a Graphic Hub server from drop-down menu or enter the address manually in form of VizDbServer@GHServer:19396 to bind to Graphic Hub server
    images/download/attachments/81472547/image2018-2-1_9-59-29.png
  3. Confirm with Apply.
    images/download/attachments/81472547/ApplyChange.png
  4. The server has been successfully changed and the binding to the previous server is removed.
    images/download/attachments/81472547/image2018-2-1_9-41-11.png
