Viz Trio User Guide
Version 3.2 | Published March 25, 2019 ©
Previous Viz Trio release highlights
Viz Trio 3.0
Main new features:
  • Significantly faster pagelist view with support for advanced filtering
  • A new main window menu making the user interface easier to navigate
  • The preview-panel and VTW template panel can be floated
  • Redesigned feed-browser
    For more information, refer to the Viz Trio 3.0 release notes.
Viz Trio 2.12.1
New features:
  • Support for meta data in media search and Viz One keyword search
  • Added the new macro commands gui:get_callup_code and playlist:select_next_by_description
    For further details, see the Viz Trio 2.12.1 release notes.
Viz Trio 2.12
Main new features:
  • Linking of tab-fields to ATOM feeds
  • Timeline editing of video elements
  • Improved Viz One integration
  • Improvements in the render video clip window
  • New script events
    Other features:
  • New editor for combo templates
  • Added macro command to launch the feed streamer moderation tool
  • Introduced saving of templates with field linking, default values and settings
  • Improved access to show and template scripts
  • Arm & fire macro commands to play out different elements on different channels simultaneously
  • The media search can incrementally display more hits
  • New macro commands for Viz Gateway configuration
  • Playlists can apply filters on groups as well
  • Configuration for as-run logging of the Media Sequencer
  • The import scene window remembers the last used folder
  • New macro command to clean up all channels of a profile
  • Added license information for included 3rd party components
  • Added last update time for MOS playlists
  • Added command to load a single page on the program and preview channel: show:load_on_renderers
    For further details, see the Viz Trio 2.12 release notes.
