Viz Trio User Guide
Version 3.2 | Published October 08, 2019 ©
To create an out animation
To create an out animation, a simple fade out animation of the whole object can be created.
Add an Alpha function to the object container.
For Viz Artist 3.x: Click the Built Ins button, and select Function Container _from the drop-list. The _Alpha function can be found in the Global folder.
For Viz Artist 2.x: Click the Function button.
Open the alpha editor.
Set the alpha value to 100% and update the animation by setting a new key.
Set the alpha value to 0.0% and update the set key again.
This has created an alpha animation in addition to the rotation animation.0
Click the Stage button and look at the animation channels:
It is possible to move the keyframes to achieve a different timing. Move keyframes either by dragging them with the mouse or by clicking on them and alter the time settings in the keyframe editor
