Viz Trio User Guide
Version 3.2 | Published October 23, 2020 ©
Installing Viz Trio
Make sure you have the correct hardware and software platform.
Make sure that Viz Engine is installed and that you have a working local Graphic Hub and Media Sequencer or have network credentials to the Graphic Hub and Media Sequencer.
Download the latest Viz Trio installer and Release Notes with FTP from download.vizrt.com/products/VizTrio/LatestVersion/
Read the Release Notes carefully. They may contain important last minute information.
Double-click the downloaded installer TrioClient-<VERSION>.msi and follow the installation instructions.
Visit docs.vizrt.com to learn more about the software or press F1 / Help > View Help to browse the local help.
IMPORTANT! You can only have one Trio installed on a server. If you have a previous version of Trio installed, the previous version will be overwritten by the new Trio installer which will attempt to preserve most data/configuration settings.
Note: Some Vizrt products and components such as NLE (Non-Linear Editing) can share a Trio installation and will therefore also be upgraded if Trio is upgraded. It is recommended to install Trio first, before installing these components. However, if these components are installed before Trio, Trio will be installed in the standard directory (C:\Program Files (x86)\vizrt\Viz Trio) even though it appears as if you can select a different directory in which to install.
