Viz Trio User Guide
Version 3.2 | Published October 08, 2019 ©
Configuring Graphic Hub Connection
Viz Trio must be configured to access the same graphics data as the Viz Engine program and preview channels. The configuration is used for local preview in order to test and preview graphics before they are added to a show or playlist and played out on-air.
As all Viz Artist and Viz Engine machines in a Viz Trio system must use the same data, it is recommended that the data be located on a high performance machine.
There are three ways to configure the Graphic Hub database using Viz Trio: at startup using the Viz Engine login window, through Viz Trio’s own configuration interface, or by setting command line options in Viz Trio’s target path.
Note: If Auto Login is set for Viz 3.x it is not possible for Viz Trio to alter the settings; however, this does not apply if Auto Login is set in the Viz Trio interface.
To configure the Viz 3.x database using Viz Engine login window
To configure the Viz 3.x database using Viz Trio configuration window
To configure the Viz 3.x database using Viz Trio target path
To configure the Viz 3.x database using Viz Config
Start the Viz Config tool and select the Database section.
Enter the following connection parameters:
Host Name: Sets the database hostname.
Hub: Sets the database name.
Port Number: Sets the database port number. Default port is 84932.
User: Sets the database user.
Auto Login: Sets login automatically when starting Viz Engine. If Auto Login is enabled it will override Viz Trio’s database login and disable its Database (Viz 3) configuration section.
Click Save, and exit the application.
Start Viz Trio.
During startup, a login window for the database will appear.
Name server host, database, username, and password
Select the Auto Login check box.
Click OK to continue.
Start Viz Trio with the following target parameter: -control
Click the Config button (upper left) to open the Configuration Interface.
Select the Graphic Hub section, and enter the following parameters:
Click Apply to save the settings, and exit the Configuration Interface.
The change of database is immediate, however, to see the change when importing scenes it might be necessary to refresh the Import Scenes view.
Note: If Auto Login is set using the Viz Config tool or Viz Engine login window (not Viz Trio) the Viz Trio Graphic Hub configuration section will be disabled.
Add the following parameters to Viz Trio's target path: –vizdb <host>:<server>:<username>:<password>
Note: Command line options will not override the database configuration if Auto Login is set using the Viz Config tool or Viz Engine login window (not Viz Trio), however, it will override settings configured using Viz Trio.
Tip: Check that the correct database is available when selecting Import Scenes.
