Viz Trio User Guide
Version 3.2 | Published October 08, 2019 ©
Video Codecs
Video codecs are only required to preview videos embedded in graphics but full screen videos can be viewed by using Timeline editor without using any codec.
IMPORTANT! Due to licensing requirements, Vizrt does not provide the codecs required for local preview. Users must obtain and install their own codecs.
Note: Playout of high resolution versions on Viz Engine do not require these video codecs.
The following procedures will guide you through the necessary installation steps:
Installation Options
Codecs are available from several suppliers. The list below includes several suggestions:
FFDShow MPEG-4 video decoder and Haali Media Splitter
LAV Filter video decoder and Splitter
Main Concept video decoder and splitter
To install codecs for local preview
The example below sets up support for h.264 playback using the FFDShow MPEG-4 codec package and a Matroska Splitter from Haali.
Note: You need to have your own license for clip playback as FFDShow does not come with a decoding license.
Make sure you do not have any other codec packages installed on the machine that interfere with FFDShow or the media splitter.
Download the Matroska Splitter from Haali
Download the Windows 7 DirectShow Filter Tweaker
Download the FFDShow MPEG-4 Video Decoder
Make sure you have a license to use the codec.
Make sure you download a 32-bit version of the codec.
Uninstall older 64-bit versions of the MPEG-4 codec.
Install the Matroska Splitter from Haali.
Install the Windows 7 DirectShow Filter Tweaker.
Install the FFDShow MPEG-4 codec.
After installing the FFDShow codec package make sure that no applications are excluded, especially Viz Engine (there is an inclusion and exclusion list in FFDShow).
Set your MPEG-4 32-bit decoder to FFDShow.
You should now be able to preview video clips from Viz One.
To set a preferred decoder
Run the Windows 7 DirectShow Filter Tweaker.
In the appearing dialog box, click Preferred decoders.
Set your MPEG-4/H.264 32-bit decoder to ffdshow and click Apply & Close.
Click Exit.
