Viz Trio User Guide
Version 3.2 | Published October 08, 2019 ©
To add text
To further improve the basic lower third a headline element and two text lines, lead by a bullet symbol, can be added.
Add a group as a sub-container to the object container, and name the group front_objects.
Add a font as a sub-container of the front_objects group container, and name it headline.
Open the text editor by clicking the text symbol of that container.
In the text editor enter the word Headline in the text input field and set the Horizontal orientation to Left. This positions the text on the right side of the Y axis to allow the text to be written from left to right.
Add a material to the font container.
Open the transformation editor to scale and position the font so that the headline is placed in the upper left corner of the lower third background.
Add a group container as a sub-container of the front_objects group, and name it bullet_1.
As sub-containers of bullet_1, add a font and any image or object that can function as a bullet symbol.
Name the text container bullet_text and the image bullet_symbol.
In bullet_text’s text editor enter the text "Bullet 1 text here".
Set the horizontal orientation to left as for the headline container.
Add a material to the bullet_text container.
Scale and position the two containers reciprocally, and then position the bullet_1 container under the headline.
Make a copy of the bullet_1 container by dragging the container while holding down the CTRL key. Position it as a sub-container of the front_objects container.
Rename the copy to bullet_2.
Adjust the Y-position of bullet_2.
