Viz Trio User Guide
Version 3.2 | Published June 29, 2021 ©
Command Line Parameters
Use the command line parameters below to customize Viz Trio startup.
Adding a Command Line Parameter
Right-click the program shortcut, and edit the program target path.
Example:
C:\Program Files (x86)\vizrt\Viz Trio\trio.exe -mse localhost -control -force_gpu_count 2
Parameter |
Value Syntax |
Description |
-attach_to_viz |
Attaches to a running viz.exe without asking the user to terminate it. |
-control |
Allows you to configure Viz Trio. |
-folder |
showpath |
Causes the client to start in the specified show. |
-force_gpu_count |
integer |
Lets the user force/override the available (detected by Viz) number of GPUs used for preview and program channel. |
-hide-auto-login |
Hides the option to auto login into the Graphic Hub database in the Viz Engine startup dialog box. |
-local_program_channel_port |
integer |
Overrides the configured port number set for the local program channel. This is useful if a different port than default port 6800 needs to be set. |
-logfile-path |
directory |
Folder in which log files are stored. |
-loglevel |
integer |
Controls how much is logged to the log file. |
-macro-port |
integer |
Overrides the port of the macro command server. The default port is 6200. |
-mse |
hostname |
Media Sequencer hostname. |
-nle-mode |
Start Viz Trio in "NLE mode". |
-no-nle-mode |
Start an NLE-compiled Viz Trio in normal (non-NLE) mode. |
-scriptloglevel |
integer |
Controls how much is logged when executing scripts. |
-socket |
Use socket (TreeTalk) for Media Sequencer communication. |
-t |
quoted string |
Redefine the main window title of Trio. %v will be replaced by the version string. %h will be replaced by the MSE-host. %s will be replaced by the current show path. |
-usersetting |
settingsname |
Use something other than the hostname as an identifier for user settings. |
-viz-console-delay |
<time in seconds> |
Starts Viz Trio independently of the Viz Engine process, enabling use of Viz Trio before Viz Engine is running. Note that the Viz Engine console is displayed in this mode (during startup) which can be used to debug Viz Engine start-up problems. |
-vizdb |
host:db:user:pw |
Configure the Viz Engine 3 database login for the local preview engine. |
-vizparams |
quoted string |
Extra parameters to pass on when starting the local Viz Engine. |
-vizpreview |
hostname: port<:protocol> |
Connect to an external Viz Engine for preview. |
-viz-startup-timeout |
integer |
Specifies the time-out to use during start-up of Viz Trio when communicating with Viz Engine. The default time-out value is set to 30 seconds. Time-outs during start-up will often leave Viz Trio unusable. After Viz Trio has successfully started up, the time-out setting in the Local Preview is used. |
