Viz Multiplay User Guide
Version 2.3 | Published August 10, 2018 ©
System Diagrams
Viz Multiplay relies on Viz Trio to import graphics from a Graphic Hub. Shows from Viz Trio are available in Viz Multiplay.
Viz Multiplay is hosted on a URL on the Media Sequencer. Any number of Viz Multiplay clients can connect to the same Media Sequencer, which provides the scheduling for playout.
The Viz Engine(s) are used for playout:
The video wall feature means that multiple DVI outputs can come from a single Viz Engine. A Viz Engine can have up to 4 GPUs, each with up to 4 DVI outputs, giving a maximum of 16 DVI outputs. See the Release Notes for hardware requirements, and note that you should check the performance of your scenes when using this configuration.
Standard SDI based playout (with one Viz Engine for each output).
Viz Multiplay can also access the media assets stored in Viz One and Media Service.
Viz Multiplay can access and use templates in a Pilot Data Server.
