GET Status of Machine Address
Returns the status for a specific machine address for the channel.
The following status codes can be returned for the system:
OK - Connection successful to Media Sequencer
CHANNEL_NOT_FOUND - Connection successful, but the channel could not be found
NO_VALID_DATA_FOUND - Connection successful, but the storage of Viz Channel Branding could not be found
CONNECTION_REJECTED - Connection was rejected
CONNECTION_TIMED_OUT - Connection timed out
Syntax
GET /config/channels/{channel}/machineaddresses/{address}/statusRequest
GET /config/channels/Test/machineaddresses/localhost/status HTTP/1.1Response - Status returned
HTTP/1.1 200 OKContent-Type: application/vizrt.promoserver+xml; type=machineAddressStatus <promoserver:machineAddressStatus xmlns:promoserver="http://www.vizrt.com/promoserver"> <promoserver:status>OK</promoserver:status></promoserver:machineAddressStatus> Error Response - Channel not found
HTTP/1.1 404 Not FoundContent-Type: application/xml; charset=utf-8<string xmlns="http://schemas.microsoft.com/2003/10/Serialization/">Element Test could not be found</string>Error Response - Address not found
HTTP/1.1 404 Not FoundContent-Type: application/xml; charset=utf-8<string xmlns="http://schemas.microsoft.com/2003/10/Serialization/">Element localhost could not be found</string>Disallowed Actions
This end-point does not allow POST, PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
