DELETE a Secondary Event under a Primary Event (Version 2.0)
Delete a Secondary Event from a playlist.
Syntax
DELETE /api/channels/[channel]/playlists/[playlist]/primaryevents/[primary_event]/secondaryevents/[secondary_event]Request
DELETE /api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0/secondaryevents/6000 HTTP/1.1Response
HTTP/1.1 204 No ContentNote: If trying to delete a non-existing Secondary Event the returned error-code will be HTTP 404, with a reference to relevant info used in the request-uri.
