Basic Mapping Table Field Names
The following field names are the basic field names used by Viz Channel Branding. Specific import types may have additional requirements.
Note: Field Name variables must follow a specific format: they should start with ASCII character (a-z/A-Z) or underscore (_), followed by alphanumeric characters (a-z/A-Z/0-9) and/or special characters (_-).
Required Field Names
If the following mandatory field names are not present during import, you will not be able to import the schedule.
  • channel: Is compared against the Channel Name in Schedule. If it does not match, primary and/or secondary events will not be imported or updated. If the schedule file has no channel name available you must leave Channel Name in Schedule blank.
  • date: The date the primary event is supposed to be played out.
  • time: The time the primary event is supposed to be played out.
  • begin_at: The combination of date and time the primary event is supposed to be played out.
  • event_id: A unique ID of the primary event, and is used to track updates. When you cannot guarantee unique event IDs, you must create a combined mapping using other Field Names (for example ReconcileKey and Segment).
    Note: The field format (date, time, etc.) depends on the data input type and is defined in Configuration settings.
Optional Field Names
The following field names are optional.
  • ignore: Used to define which Primary Events Ignore Settings for Page Content Filling. An update of your playlist is always required if these settings are changed.
  • duration: Is the duration of the primary event. An invalid duration value will be regarded as an empty value.
  • description: Is the description of the primary/secondary event.
  • event_type: Is the type of event, primary or secondary. Values for primary and secondary event types are set in the Mapping Settings.
  • trigger_id: Is the ID for triggering events by the automation system.
  • secondary_page: Is the page name, and must match the name of the page created in Viz Channel Branding Client. See Working with Templates and Pages.
  • secondary_timecode: Offset relative to the primary event’s start time.
  • secondary_duration: Duration of the secondary event. An invalid duration value will be regarded as an empty value.
  • house_id: Map the house ID to the house_id keyword. This enables the system to resolve assets on Viz One (see the Viz One Integration chapter). Will create a composite group (a primary element containing a video asset) in your playlist . The composite group may also contain pages. This requires Viz One 5.4 or later.
  • isLive: The value can be ‘1’ or ‘true’ for live events, not case sensitive.
  • isLocked: The value can be ‘1’ or ‘true’ if the event is locked, not case sensitive.
    Note: When a live event is scheduled at a preset time, the timetrigger will pause. The elements following the live event will be scheduled only when the user clicks Continue from the LIVE show button. When a playlist is resumed from a live event earlier or later than planned, the begin time of events following the live event are shifted to be taken on air immediately. The begin time of events will be adjusted up until the first locked event.
Additional Field Names
Additional field names can be used to add in extra columns in the playlist to show metadata or to add data to pages when editing an attribute (see Page Content Filling Window’s Attribute options). You can define as many additional Field Names as you like. Additional Field Names are supported by any format apart from the LST Import Type.
