GET Channel
Returns a definitions for a single specific channel.
Syntax
GET /config/channels/{channel}Request
GET /config/channels/Test HTTP/1.1Response - Channel returned
HTTP/1.1 200 OKContent-Type: application/vizrt.promoserver+xml; type=channel<promoserver:channel xmlns:promoserver="http://www.vizrt.com/promoserver"> <promoserver:refLink rel="self" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/Test" /> <promoserver:refLink rel="edit" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/Test" /> <promoserver:refLink rel="machineaddresses" type="application/vizrt.promoserver+xml; type=machineAddressesList" href="http://localhost:9980/config/channels/Test/machineaddresses" /> <promoserver:name>Test</promoserver:name> <promoserver:machineAddressInUse>localhost</promoserver:machineAddressInUse></promoserver:channel>Error Response - Channel not found
HTTP/1.1 404 Not FoundContent-Type: application/xml; charset=utf-8<string xmlns="http://schemas.microsoft.com/2003/10/Serialization/">Element Test could not be found</string>Disallowed Actions
This end-point does not allow POST, and will return a 'HTTP/1.1 405 Method Not Allowed'.
