GET Primary Event (Version 2.0)
Following the downlink while retrieving the collection of Primary Events under a Playlist one can also do a GET directly on a single Primary Event.
Take note that the collection of entries under meta_data sub-section is not set in size or content, and depends on the actual meta data attributes on the primary event in the playlist.
Syntax
GET /api/channels/[channel]/playlists/[playlist]/primaryevents/[primary_event]Request
GET /api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0 HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshubv2+xml; type=primaryevent<inthub:primaryEvent xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:inthub="http://www.vizrt.com/integrationshub"> <inthub:name>primary_element_1_0_0</inthub:name> <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=primaryevent" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0" /> <inthub:refLink rel="secondaryevents" type="application/vizrt.integrationshubv2+xml; type=list" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0/secondaryevents" /> <inthub:refLink rel="edit" type="application/vizrt.integrationshubv2+xml; type=primaryevent" href="http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/primary_element_1_0_0" /> <inthub:description>Le radeau LE CRASH DU VOL 29</inthub:description> <inthub:startTime>2008-04-23T03:48:17.280Z</inthub:startTime> <inthub:duration>08:58:13.000</inthub:duration> <inthub:ignore>false</inthub:ignore> <inthub:triggerId /> <inthub:houseId /> <inthub:markIn /> <inthub:markOut /> <inthub:isLocked>false</inthub:isLocked> <inthub:isLive>false</inthub:isLive> <inthub:isManuallyEdited>false</inthub:isManuallyEdited> <inthub:available>1.00</inthub:available> <inthub:loaded>1.00</inthub:loaded> <inthub:infoIntegrationsHub>[A:11:47:44]</inthub:infoIntegrationsHub> <inthub:createdBy>schedule</inthub:createdBy> <inthub:error /> <inthub:metadata> <inthub:attribute name="date">2008-04-23</inthub:attribute> <inthub:attribute name="time">05:48:17:07</inthub:attribute> <inthub:attribute name="event_type">MAIN</inthub:attribute> </inthub:metadata></inthub:primaryEvent>Disallowed Actions
This end-point does not allow POST, and will return a 'HTTP/1.1 405 Method Not Allowed'.
