Viz Multichannel
Version 4.2 | Published July 31, 2020 ©
GET Secondary Event (Version 2.0)
Following the downlink while retrieving the collection of Secondary Events under a Primary Event one can also do a GET directly on a single Secondary Event.
Take note that the collection of entries under meta_data sub-section is not set in size or content, and depends on the actual meta data attributes on the secondary events in the playlist.
Syntax
GET /api/channels/test/playlists/continuous/primaryevents/[primary_event_id]/secondaryevents/[page_name]
Request
GET /api/channels/test/playlists/continuous/primaryevents/[primary_event_id]/secondaryevents/[page_name] HTTP/
1.1
Response
HTTP/
1.1
200
OK
Content-Type: application/atomsvc+xml
<atom:entry xmlns:vaext=
"http://www.vizrt.com/atom-ext"
xmlns:vizid=
"http://www.vizrt.com/opensearch/vizid"
xmlns:xsi=
"http://www.w3.org/2001/XMLSchema-instance"
xmlns:inthub=
"http://www.vizrt.com/integrationshub"
xmlns=
"http://www.w3.org/2007/app"
xmlns:atom=
"http://www.w3.org/2005/Atom"
<inthub:name>b6fdce17-2ac8-4ae0-9f46-e11770b547da</inthub:name>
<atom:id>b6fdce17-2ac8-4ae0-9f46-e11770b547da</atom:id>
<atom:link rel=
"self"
type=
"application/atom+xml; type=entry"
href=
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/primaryevents/1051867_1_VM_16_01_1/secondaryevents/b6fdce17-2ac8-4ae0-9f46-e11770b547da"
<atom:link rel=
"edit"
type=
href=
<atom:meta_data>
<atom:attribute name=
"continue_count"
0
</atom:attribute>
"guid"
2018
11
-06T10:
53
:02Z_Johan-PC2.vizrt.internal_12020_0</atom:attribute>
"infoPromoServer"
20
28
58
]</atom:attribute>
"modified_date"
2018
11
-06T10:
53
02
.224Z</atom:attribute>
"showautodescription"
true
</atom:attribute>
"templatedescription"
>Lower third</atom:attribute>
</atom:meta_data>
<inthub:description>Preview: Man of Steel/You are watching</inthub:description>
<inthub:obj_id>
6000
</inthub:obj_id>
<inthub:timecode>
00
00
10
00
</inthub:timecode>
<inthub:take_count>
0
</inthub:take_count>
<inthub:duration>
00
00
12
00
</inthub:duration>
<inthub:created_by>schedule</inthub:created_by>
<inthub:infoIntegrationsHub>[U:
14
02
56
]</inthub:infoIntegrationsHub>
</atom:entry>
