Viz Multichannel
Version 4.2 | Published July 31, 2020 ©
GET Channel Settings (Version 2.0)
Get the complete settings for a specific channel. Modifying settings can only be done via Multichannel Channel Settings UI.
Syntax
GET /api/channels/test/settings
Request
GET /api/channels/test/settings HTTP/
1.1
Response
HTTP/
1.1
200
OK
Content-Type: application/atomsvc+xml
<atom:entry xmlns:vaext=
"http://www.vizrt.com/atom-ext"
xmlns:vizid=
"http://www.vizrt.com/opensearch/vizid"
xmlns:xsi=
"http://www.w3.org/2001/XMLSchema-instance"
xmlns:inthub=
"http://www.vizrt.com/integrationshub"
xmlns=
"http://www.w3.org/2007/app"
xmlns:atom=
"http://www.w3.org/2005/Atom"
<inthub:name>settings</inthub:name>
<atom:id>settings</atom:id>
<atom:link rel=
"self"
type=
"application/atom+xml; type=entry"
href=
"http://localhost:9991/api/channels/test/settings"
<inthub:general>
<inthub:entry name=
"GeneralSettings.BasicSettings.ChannelBasicInfo.ScreenDimension"
1920
1080
</inthub:entry>
<inthub:entry name=
"GeneralSettings.BasicSettings.ChannelBasicInfo.AspectRatio"
16
9
</inthub:entry>
<inthub:entry name=
"GeneralSettings.BasicSettings.ChannelBasicInfo.FramesPerSec"
25
</inthub:entry>
<inthub:entry name=
"GeneralSettings.BasicSettings.ChannelBasicInfo.BroadcastDayStartTime"
04
00
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.BasicSettings.TriggeringControl.TimedPlayout"
false
</inthub:entry>
<inthub:entry name=
"GeneralSettings.BasicSettings.TriggeringControl.TriggerType"
>Primary Events</inthub:entry>
<inthub:entry name=
"GeneralSettings.BasicSettings.PlaylistDateManagement.AllEventsInOnePlaylist"
true
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.Timezone.ChannelTimeZone"
07
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.Timezone.ScheduleTimeZone"
07
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.DSTSetting.ChannelInDSTTimeZone"
false
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.DSTSetting.DynamicDSTSetting"
true
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.DynamicDSTSetting.DynamicStartDate"
6
7
3
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.DynamicDSTSetting.DynamicStartTime"
01
00
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.DynamicDSTSetting.DynamicEndDate"
6
7
10
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.DynamicDSTSetting.DynamicEndTime"
02
00
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.ExplicitDSTSetting.ExplicitStartDate"
01
08
2013
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.ExplicitDSTSetting.ExplicitStartTime"
01
00
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.ExplicitDSTSetting.ExplicitEndDate"
31
08
2013
</inthub:entry>
<inthub:entry name=
"GeneralSettings.TimezoneSettings.ExplicitDSTSetting.ExplicitEndTime"
02
00
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.GeneralPlayoutOptions.AllowItemReplay"
true
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistOptions.IsAutoExpandRunningElement"
true
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistOptions.LockViewToRuningPrimaryEvent"
false
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistOptions.DefaultPrimaryEventDuration"
00
10
00
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistOptions.DefaultLiveEventDuration"
01
00
00
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.EditOptions.ClearPageIdAfterEdit"
false
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.SceneImport.ReportDVEErrors"
false
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.VizOneIntegration.AutoExtractVizOneMetaData"
false
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistArchiving.EnableArchiving"
false
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistArchiving.ArchivingNumOfDays"
0
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistArchiving.ArchivingFolder"
></inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistArchiving.ArchivingTime"
00
00
00
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.PlaylistArchiving.DeletePages"
0
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.DefaultScenes.AutomaticallyTakeLogoPage"
false
</inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.DefaultScenes.LogoScene"
></inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.DefaultScenes.ErrorScene"
></inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.DefaultScenes.VideoOnlyScene"
></inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.QuickTakePages"
></inthub:entry>
<inthub:entry name=
"GeneralSettings.Miscellaneous.Reporting.PlaylistReportsFolder"
>C:\ProgramData\Vizrt\Multichannel\Reports\Playlist</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.ChannelName.ChannelName"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.RemoteHosts.RemoteHosts"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.AutomaticImportSettings.EnableAutomaticImport"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.AutomaticImportSettings.ImportFolder"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.AutomaticImportSettings.UpdateFolder"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.ImportOptions.CreatePlaceholderForHouseId"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.ImportOptions.ImportSecondaryAsRef"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.ImportOptions.RemoveSecondaryEventsExceedingPrimaryDuration"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.ImportOptions.AllowPagesByRulesWithOffsetExceedingPrimaryDuration"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.ImportOptions.AllowPageToForceMappingForPageContentFilling"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.PageContentFilling.RefreshPageContentofPlaylist"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.PageContentFilling.RefreshPageContentofRunningPlaylist"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.PageContentFilling.SkipRefreshAlreadyPlayedPage"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.PageContentFilling.PromoServerAddress"
>localhost</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.PageContentFilling.TranslationTables"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.DaySwitchOptions.DaySwitchOptions.ActivateDaySwitch"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.DaySwitchOptions.DaySwitchOptions.ActivatePlaylist"
00
00
00
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.DaySwitchOptions.DaySwitchOptions.InsertCleanUp"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.DaySwitchOptions.DaySwitchOptions.TimeBeforeCleanUp"
00
00
00
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.DaySwitchOptions.DaySwitchOptions.InsertInitialize"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.DaySwitchOptions.DaySwitchOptions.TimeBeforeInitialize"
00
00
00
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.FilteringOptions.ImportWindow.ImportStartOffset"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.FilteringOptions.ImportWindow.ImportEndOffset"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.FilteringOptions.ImportWindow.ImportPrimaryEventsOutsideImportWindow"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.FilteringOptions.ImportWindow.MarkPartiallyImportedScheduleAsDone"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.FilteringOptions.PrimaryEventFiltering"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.AutomaticUpdateMode"
>Full</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.DeleteProcessedFiles"
2
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.MSELockEvents"
00
01
00
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.ClearPlayedEvents"
00
00
00
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.ClearUnplayedEvents"
00
00
00
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.AllowUpdatesOfRunningPlaylist"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.LockEditedPageWhenUpdate"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.AllowUpdatesOfAlreadyPlayedSecondaryEvents"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.RetrieveDateFromRunningPlaylist"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.CreatePlaylistIfNotExists"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.SendPlaylist"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.SendPages"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.SendActions"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateOptions.SendPagesWhenNoop"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.FullUpdateOptionsForSecEvents.GetFromExternalPlaylist"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.FullUpdateOptionsForSecEvents.RescheduleByRules"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.FullUpdateOptionsForSecEvents.LeaveManuallyAddedItems"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateTimeOptionsForSecEvents.GetFromExternalPlaylist"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateTimeOptionsForSecEvents.RescheduleByRules"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.UpdateSettings.UpdateTimeOptionsForSecEvents.LeaveManuallyAddedItems"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.ExportOptions.AutoExportFolder"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.ExportOptions.ChannelNameInAutomation"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.ExportOptions.ExportSecEventsWithNoOffset"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.SecEventIDAssignment.AssignmentMode"
>Regenerate</inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.SecEventIDAssignment.GenerateRandomId"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.SecEventIDAssignment.CapitalLettersForRandomId"
true
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.SecEventIDAssignment.PrefixSecondaryId"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.SecEventIDAssignment.InitialSecondaryId"
></inthub:entry>
<inthub:entry name=
"Import_slash_Export.ExportSettings.Harris.MergeIntoExistingFile"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GraphicSettings.GraphicSettings.IncludeGraphicsWhenSendingPlaylist"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GraphicSettings.GraphicSettings.IncludeGraphicsWhenReceivingPlaylist"
false
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GraphicSettings.GraphicSettings.SharedVizArchiveFolder"
></inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.IsEnabled"
false
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.BitsPerSecond"
19200
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.Port"
>----</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.StopBits"
1
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.DataBits"
8
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.Parity"
>None</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.FlowControl"
>None</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.BoxType"
>SRC-
8
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.IP"
></inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.Unit"
0
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIDeviceDefinition.SlaveId"
0
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.GPI.GPIActionsMapping"
></inthub:entry>
<inthub:entry name=
"ExternalTriggering.VDCP.IsEnabled"
false
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.VDCP.VDCP.IsForceExtendedMode"
false
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.VDCP.VDCP.BitsPerSecond"
38400
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.VDCP.VDCP.Port"
>----</inthub:entry>
<inthub:entry name=
"ExternalTriggering.VDCP.VDCP.ByteSize"
8
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.VDCP.VDCP.ExtraStopBits"
1
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.VDCP.VDCP.Parity"
1
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.IntelligentInterface.IsEnabled"
false
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.IntelligentInterface.IntelligentInterface.BitsPerSecond"
19200
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.IntelligentInterface.IntelligentInterface.Port"
>----</inthub:entry>
<inthub:entry name=
"ExternalTriggering.IntelligentInterface.IntelligentInterface.Encoding"
>UTF-
8
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.IntelligentInterface.IntelligentInterface.Space"
false
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.TCP.IsEnabled"
false
</inthub:entry>
<inthub:entry name=
"ExternalTriggering.TCP.TCP.Port"
></inthub:entry>
<inthub:entry name=
"ExternalDataSources.DatabaseConnections.DatabaseConnections.Links"
></inthub:entry>
<inthub:entry name=
"ExternalDataSources.UpdateService.UpdateService.HostName"
>http:
//localhost:56999</inthub:entry>
<inthub:entry name=
"ExternalDataSources.UpdateService.UpdateService.Take"
true
</inthub:entry>
<inthub:entry name=
"ExternalDataSources.UpdateService.UpdateService.TakeTimeout"
5
</inthub:entry>
<inthub:entry name=
"ExternalDataSources.UpdateService.UpdateService.Preview"
true
</inthub:entry>
<inthub:entry name=
"ExternalDataSources.UpdateService.UpdateService.PreviewTimeout"
5
</inthub:entry>
<inthub:entry name=
"ExternalDataSources.UpdateService.UpdateService.Update"
true
</inthub:entry>
<inthub:entry name=
"ExternalDataSources.UpdateService.UpdateService.UpdateTimeout"
5
</inthub:entry>
<inthub:entry name=
"Import_slash_Export.GeneralSettings.ImportOptions.AllowUsingPilotDataServerElement"
true
</inthub:entry>
</inthub:general>
<inthub:mappings>
<inthub:mapping xsi:type=
"inthub:xml"
type=
"Any XML"
<inthub:filenamepattern>*.xml</inthub:filenamepattern>
<inthub:schedulefilenameinfo />
<inthub:columnmappings>
<inthub:columnmapping field_name=
"channel"
"ignore"
"date"
"time"
<inthub:columnmapping column=
"@dateT@time"
field_name=
"begin_at"
caption=
"Begin Time"
"duration"
caption=
"Duration"
edit_events=
"true"
"timecode"
caption=
"Offset"
edit_events=
"true"
"description"
caption=
"Description"
edit_events=
"true"
"event_id"
caption=
"Event ID"
"trigger_id"
caption=
"Media ID"
"event_type"
</inthub:columnmappings>
<inthub:primarydateformat>DD/MM/YYYY</inthub:primarydateformat>
<inthub:isbroadcastdate>
false
</inthub:isbroadcastdate>
<inthub:primaryeventtype>MAIN</inthub:primaryeventtype>
<inthub:secondaryeventtype>SECONDARY</inthub:secondaryeventtype>
<inthub:isdefaultbehavior>
false
</inthub:isdefaultbehavior>
<inthub:ignorevalues />
<inthub:primaryeventpath>/</inthub:primaryeventpath>
<inthub:secondaryinsideprimaryevents>
false
</inthub:secondaryinsideprimaryevents>
<inthub:secondaryeventpath>/</inthub:secondaryeventpath>
<inthub:channelnodelocationtakenfromroot>
true
</inthub:channelnodelocationtakenfromroot>
<inthub:datenodelocationtakenfromroot>
true
</inthub:datenodelocationtakenfromroot>
</inthub:mapping>
</inthub:mappings>
<inthub:primaryeventfilters />
</atom:entry>
Disallowed Actions
This end-point does not allow POST, PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
