Viz Multichannel
Version 4.2 | Published July 31, 2020 ©
DELETE a Primary Event in a Playlist (Version 2.0)
Delete a Primary Event from a playlist.
Syntax
DELETE /api/channels/test/playlists/[playlist_id]/[primary_event_id]
Request
DELETE /api/channels/test/playlists/continuous/primaryevents/1051111_1_VM_16_01_1 HTTP/
1.1
Response
HTTP/
1.1
200
OK
Note
If trying to delete a non-existing Primary Event the returned error-code will be HTTP 404, with a reference to relevant info used in the request-uri.
