Viz Multichannel User Guide
Merging Fields
The correct format for merging (joining) fields is:
freetext<at:var at:name=
"FIELDNAMEfreetext"
/>FIELDNAMEfreetext…
where free-text can be empty (FIELDNAME@FIELDNAME).
Example: @Hour:@Minute:@Second
The mapping is divided into two: one for each field reading its values, and one for concatenating (merging) them.
IMPORTANT! The merging field must be located in the table after its parts-fields.
Example 1 for Fixed Width Any Text Import Type
StartHour = $L(1,2)
StartMin = $L(3,4)
StartSecond = $L(5,6)
Begin = @StartHour:StartSecond
Example 2 for Delimited Any Text Import Type
StartHour = $L(4)
StartMin = $L(5)
StartSecond = $L(6)
Example 3 for Any XML Import Type
This example shows time read in a format HH-MM-SS-FF from an entry /begin_time/time/.
TheStartTime = /begin_time/time/
StartHour = &(TheStartTime,”-”,1,1)
StartMin = &(TheStartTime,”-”,2,1)
StartSecond = &(TheStartTime,”-”,3,1)
StartFrame = &(TheStartTime,”-”,4,1)
Begin = @StartHour:@StartMin:@StartSecond:@StartFrame
