Viz Multichannel
Version 4.2 | Published July 31, 2020 ©
GET Playlist State (Version 2.0)
Retrieve the state-information of a playlist.
Syntax
GET /api/channels/test/playlists/continuous/state
Request
GET /api/channels/test/playlists/continuous/state HTTP/
1.1
Response if Playlist is RUNNING
HTTP/
1.1
200
OK
Content-Type: application/atomsvc+xml
<atom:entry xmlns:vaext=
"http://www.vizrt.com/atom-ext"
xmlns:vizid=
"http://www.vizrt.com/opensearch/vizid"
xmlns:xsi=
"http://www.w3.org/2001/XMLSchema-instance"
xmlns:inthub=
"http://www.vizrt.com/integrationshub"
xmlns=
"http://www.w3.org/2007/app"
xmlns:atom=
"http://www.w3.org/2005/Atom"
<inthub:name>continuous</inthub:name>
<atom:id>_slash_VizRundown_slash_channels_slash_test_slash_playlists_slash_continuous</atom:id>
<atom:link rel=
"self"
type=
"application/atom+xml;type=entry"
href=
"http://127.0.0.1:9991/api/channels/test/playlists/continuous/state"
<inthub:description>Continuous Playlist</inthub:description>
<inthub:playlist>/VizRundown/channels/test/playlists/continuous</inthub:playlist>
<inthub:user>NN</inthub:user>
<inthub:state>running</inthub:state>
</atom:entry>
Response if Playlist is STOPPED
HTTP/
1.1
200
OK
xmlns:vizid=
xmlns:xsi=
xmlns:inthub=
xmlns=
xmlns:atom=
<atom:link rel=
"self"
type=
href=
<inthub:state>stopped</inthub:state>
</atom:entry>
Disallowed Actions
This end-point does not allow POST, PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
