Text FX Jitter Position
The Text FX Jitter Position plug-in creates an jittering motion of the characters by randomly changing the position of each character. The degree of position change and the starting sequence of the jittering can be altered. To use the function add it onto a container which holds a font. To create an animation, animate the progress. Other values can of course be animated as well.
Text FX Jitter Position Properties
Use Axis defines on which axis or axes the characters moves to create the jittering effect.
Lock Axis with this option enabled Range and Randomness will be the same for all axes. If you disable it, Range and Randomness for each of the axes will be shown and you can set them individually.
Range sets the range of the jittering movement.
Randomness sets the intensity of the jittering movement.
