Area Chart
Th Area Chart plug-in draws an area chart, filled with data out of a Shared Memory Map. You can use delimited strings or arrays for data transfer via Scene, Global or Distributed Shared Memory.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> VisualDataTools
Area Chart Properties
Shared Mem.: Change between Scene, Global and Distributed Shared Memory. Use Inactive memory to not forward any values via Shared Memory
Specify X Values: Enable DataX input
Key DataX: Shared Mem. key name for X values
DataX: Parameter for X values if Shared Memory is set to Inactive
Key DataY: Shared Mem. key name for Y values
DataY: Parameter for Y values if Shared Memory is set to Inactive
Transfer Mode: Set string or array based data transfer (not available when set shared memory is set to Inactive)
Data Delim.: Define the value separator sign(s)
Number Format: Defines if Viz should get the decimal point separator from the System Locale or Custom settings. If Custom is enabled,
Decimal Symbol: Defines which symbol is used as decimal point when Custom Number Format is set.
Note: If the Area Stack plug-in is used, the following Area Chart properties need to be defined in the Area Stack plug-in.
DataX, Y Fit: Enable data normalization
DataX, Y Scale: Scale input by the selected factor
DataX, Y Offset: Add an offset to the incoming data
DataX, Y Auto Scale: Enable automatic data normalization
DataX, Y Fit Size: Total scale the whole chart to the defined borders. Current scales the current chart segment to the set borders
DataX, Y Detect Limits: Detect minimum and maximum of all values and scales them to adjusted Start and Stop. This option is used to upscale the interesting part of the chart - especially if there are only little changes between the data values
DataX, Y Threshold: Add a definable offset to the detected limit
DataX, Y Start: Lower Auto Scale edge
DataX, Y Stop: Upper Auto Scale edge
Data Animation: Set the animation type to be created when data change is detected:
Disable: No animation
Timer: Create data transition animation (from an old set of data to a new set) within the specified time set in Duration sec.. Also select an Animation Mode
Director: Create data transition animation with the Stage Director, that controls the Animation Progress parameter from 0.0% (old data) to 100.0% (new data). Also select an Animation Mode
Animation Mode:
Concurrent: All nodes change concurrently
Left to Right: Transition from left to right
Right to Left: Transition from right to left
Balance Speed: Set to On, when Animation Mode is set to Left to Right or Right to Left, and the position of transformed data will be related to node values as well
Example:Balance Speed: If the values of four nodes change from 0,0,0,0 to 1,9,90,900 in Left to Right mode at 50% of the transformation. Balance Speed Off: Only the first two nodes will be transformed to new values. Balance Speed On: The first three nodes are already transformed to new values, and the last node also transformed to 44% of the new values, because the data change from 0 (0+0+0+0) to 1000 (1+9+90+900), at 50% of transformation (in this case the values is changed for 500 of 1000), the first 3 nodes are already finished and the last node is changed to 400
Durationsec.: Set the duration of the animation in seconds for Timer mode
Horizontal Alignment: Sets horizontal orientation to left, center or right.
Type: Create different graph looks. Available options are Normal, Spline, Staircase and Constrained Spline.
Normal: Enable direct connections between entered values
Spline: Interpolate extra values to chamfer the graph
Staircase: Create a staircase look
Constrained Spline: Same as Spline mode but with a different algorithm to prevent overshooting
Stair Width: Define width for a single stair or for all stairs if Specify X Values is activated
Chart Width: Adjust the chart width
Chart Depth: Adjust extrusion
Tesselation Width: Set tessellation in Spline mode
Selection: Specify Start and Stop type
Relative: 0%: 100%
Absolute: Depend on the specified data
ID: Value ID starting from 0
Start%, abs,: Graph starting point
Stop%, abs,: Graph stopping point
Reposition Start: Translate the whole chart always to the same starting point independent of varying Start and Stop positions
Bevel: Activate Bevel mode
Bevel Bottom: Chamfer the chart’s bottom
Bevel Size: Adjust bevel’s size
Bevel Steps: Set roundness via the number of segmentation steps
Note: A chamfer is a beveled edge connecting two surfaces.
RelativeMapping: Stretch texture to fit graph width
Pos. Container: Translate every child container to a bar’s top
Container Offset: Add a certain offset to each container
Container Offset Z: Add a Z Axis offset to each container
Center Container: Center each translated container
Pointers Shared Mem.: Select the map where the pointer values should be distributed to
Key Data Pointers: Define Shared Memory Keyname
Pointer: Activate the Pointer
Container: Define Container which should be used as pointer
Selection: Select the navigation type
Position%, abs,: Set pointer position in dependency of the selected navigation type
Offset: Define pointer offset from the chart
Normal Offset: Rotate offset to the direction of the current surface normal
Rotate: Rotate the pointer to the direction of the current surface normal
Offset Z: Add an additional Z offset to the pointer container
Center Container: Center Container - useful for varying pointer sizes
Pointers: Activate each pointer as required:
Low Pointer / High Pointer / Start Pointer / Stop Pointer
Container: Select a container for the pointer
To Create a Scene with Area Chart
Create a new Container.
Add the Area Chart plug-in.
Open the Transformation Editor.
Set these parameters:
Position X: -100.0.
Position Y: -100.0.
Rotation Y: -25.0.
Add a Material and/or a Texture.
Open the Area Chart editor.
Enter these parameters:
Set DataY values: 10,20,30,20,50,60,80,45,20.
Set Type to Spline.
Set Chart Width to 200.0.
Set Chart Depth to 30.0.
To Create a Scene with Area Chart and Data Storage
Add the Data Storage plug-in to Area Chart Container.
Select the Area Chart plug-in.
Set SharedMem. to Scene.
Rename the Key DataY to MyDataY.
Open the Data Storage editor.
Enter MyDataY in the Key Data1 field.
Set the SharedMem. to Scene.
In Data1 enter: 10,40,50,20,80,90,60,50.
