Control Clock
The Control Clock plug-in allows the user to set time for a clock as well as controlling several clock functions. The clock object is a text container in the scene with the clock function enabled.
Control Clock Properties
Expose Limit: Enable the user set a limit for the clock
Expose Direction: Enable the user to choose the direction for the clock
Action: Set the clock action that will be the default value in the control client’s clock editor
Input Value: Show the current value for the plug-in. It is not necessary to set any value here. It is normally only used for debugging purposes
