Scene Tree Shortcuts
General Shortcuts
Function |
Show Tree View |
Ctrl+1 |
Show Sort View |
Ctrl+2 |
Show Search View |
Ctrl+3 or Ctrl+F |
Show DVE Media Asset Manager |
Ctrl+4 |
Show Texture Media Asset Manager |
Ctrl+5 |
Refresh |
Ctrl+R |
Select all Containers |
Ctrl+A |
<Ctrl-Shift-A> toggles the auto grab focus. This is toggles the auto grab focus to and from the Property Editor. When auto grab focus is on the Property Editor, the shortcuts below do not work.
Tip: This enables a user to work with objects without the need to click into the Property Editor again.
Function |
Key and/or Mouse |
Go to Top Container |
Home |
Go to Last Container |
End |
Go to top of page |
Page Up |
Go to bottom of page |
Page Down |
Scroll up the Container list |
Cursor up |
Scroll down the Container list |
Cursor down |
Open or close the Container tree |
Return, or the numeric keyboard Return |
Basic View Controls and Shortcuts
Function |
Key and/or Mouse |
Insert New Container |
Ctrl+Insert The new Container will be created above the first selected Container. |
Multi select Containers |
Ctrl+Right click |
Delete Selected Container(s) |
Ctrl+Delete |
Open Tree |
Ctrl+O |
Collapse Tree |
Ctrl+I |
Lock Selected Container(s) |
Ctrl+L |
Unlock Selected Container(s) |
Ctrl+Shift+L |
Group Selected Container(s) |
Ctrl+G |
Ungroup Selected Container(s) |
Ctrl+Shift+G |
Hide Selected Container(s) |
Ctrl+H |
Show Selected Container(s) |
Ctrl+Shift+H |
Undo |
Ctrl+Z |
Redo |
Ctrl+Y |
Save the Scene |
Ctrl+S |
Copy Selected Container(s) |
Ctrl+Left click on container name and drag |
Copy Selected Container(s) to Clipboard |
Ctrl+C |
Paste Containers from Clipboard |
Ctrl+V They will be created one hierarchical level underneath selected container. |
Cut Selected Container(s) |
Ctrl+X |
Move Selected Container(s) |
Move Selected Container and retain transformation properties |
Alt+Left click on container name and drag |
Copy Properties of Container |
Left click on container Properties and drag |
Merge Group |
Ctrl+M |
Split Container |
Ctrl+Shift+M |
Sort View Shortcuts
Function |
Key and/or Mouse |
Sort by Vertices |
Ctrl+Q |
Sort by Render Time |
Ctrl+W |
Sort by Texture Size |
Ctrl+E |
Toggle Unique for Texture Size |
Ctrl+T |
