Look-At
The Look-At plug-in is used to rotate a Container so that it faces a defined direction. This is especially valuable in animations.
This section also contains information on the following topic:
Look-At Properties
Auto Rotation
None: No rotation
Billboard: Will rotate the container to face the camera
Follow Path: Will rotate the container to justify at the animation path
Keep Size:
Billboard Axis: Only with Billboard:
X: The container will rotate about its X-axis to face the camera, even if camera moves
Y: The container will rotate about its Y-axis to face the camera, even if camera moves
XY Camera: The container will rotate about its X- and Y-axis to face the camera, even if it moves
XY Screen: The container will rotate about its X and Y-axis to face the camera if the camera orbits the container only
