Control Action Table
The Control Action Table plug-in allows defining a table of actions similar to Control Action. The actions are associated with a given value. When Control Action Table receives input, it compares the received data to each of the values. If the data matches one of the values the plug-in starts the corresponding action.
Control Action Table Properties
Input Value: Specifies the value input will be compared against.
Notify Only When Value Change: Triggers a command when a value is changed.
Value 1/2: The value that the given action should be associated with.
Action 1/2: Actions to execute if value match.
Default Action: Will be executed if the input does not match any of the specified values.
