Pie Chart
This plug-in draws a pie chart, filled with data out of a Shared Memory Map. You can use delimited strings or arrays for data transfer via Scene-, Global- or Distributed-Shared Memory.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> VisualDataTools
Pie Chart Properties
Shared Mem.: Changes between Scene-, Global- and Distributed-Shared Memory. Use Inactive memory to not forward any values via Shared Memory
Data: Shared Mem. key name. Data is the default input parameter
Transfer Mode: Sets string- or array-based data transfer
Data Delim.: Defines the value separator sign(s)
Number Format: Defines if Viz should get the decimal point separator from the System Locale or Custom settings. If Custom is enabled,
Decimal Symbol: Defines which symbol is used as decimal point when Custom Number Format is set.
Data Fit: Enables data normalization
Data Offset: Adds an offset to the incoming data
Data Animation: Set the animation type to be created when data change is detected:
Disable: No animation
Timer: Create data transition animation (from an old set of data to a new set) within the specified time set in Duration sec.. Also select an Animation Mode
Director: Create data transition animation with the Stage Director, that controls the Animation Progress parameter from 0.0% (old data) to 100.0% (new data). Also select an Animation Mode
Animation Mode:
Concurrent: All nodes change concurrently
Left to Right: Transition from left to right
Right to Left: Transition from right to left
Balance Speed: Set to On, when Animation Mode is set to Left to Right or Right to Left, and the position of transformed data will be related to node values as well
Example:Balance Speed: If the values of four nodes change from 0,0,0,0 to 1,9,90,900 in Left to Right mode at 50% of the transformation. Balance Speed Off: Only the first two nodes will be transformed to new values. Balance Speed On: The first three nodes are already transformed to new values, and the last node also transformed to 44% of the new values, because the data change from 0 (0+0+0+0) to 1000 (1+9+90+900), at 50% of transformation (in this case the values is changed for 500 of 1000), the first 3 nodes are already finished and the last node is changed to 400
Durationsec.: Set the duration of the animation in seconds for Timer mode
Diameter: Sets pie’s size
Total Segmentdeg: Set’s the pie’s maximum angle in degrees (default: 100% are equal to 360 degrees)
Inner Cutoff: Cuts off a round piece from the cake’s center
Height: Adjust height
Corners: Defines the minimum amount of corners at the pie’s edge. In dependency on the number of pieces an algorithm adds corners to give the cake always the same appearance
Keep Proportions: If enabled, the cake would look like a real one. Otherwise each piece’s radius is recalculated
Const. Offset: Sets a constant gap width
Center Offset: Every pieces’ distance from the pie’s center
Piece Scaling: All: All pieces equal 100%. Single: Every piece’s size is described by it’s own 100%(e.g. 3 pieces mean 300%). Fit: All pieces equal 100%, but they are scaled relatively to fit their new area with the correct values
Piece Size%: Parameter for the previous option
Bevel: Activates Bevel mode
Bevel Top: Chamfer cake’s top
Bevel Bottom: Chamfer pie’s bottom
Bevel Size%: Adjusts bevel’s size from 0 to 100
Bevel Steps: Sets roundness via the number of segmentation steps.
Move Piece: Defines the piece for the next parameter operation. Starts with 0, -1 means nothing selected
Center Offset: Additional center shift for a certain piece
Height Offset: Additional height shift for a certain piece
Effect Range: Sets the range of pieces to move
Effect Distribution: Sets the distribution of the effect range
Pos. Container: Translates every child container to a piece of cake
Container Offset: Adds a certain center offset to each container
Center Container: Centers each translated container
PosX, Y, Z: Activates container translation on the particular axis
Container Pos. Z%: Sets the relative position on the z axis for each child container
Map:
Color Bar: Sets a single color (V texture coordinate) for a certain piece(e.g. 3 pieces: V = 0.0, V = 0.5 and V = 1.0)
Vertex: Use vertex colors for each piece starting with ID 0. Color ID moves between the available vertex colors. Color lets you choose color for the current ID
Note: A chamfer is a beveled edge connecting two surfaces.
To Create a Pie Chart
Create a new group and add the Pie Chart plug-in to it.
Open the Transformation Editor and set Position X and Y to -100.0 and Rotation Y to -25.0.
Add a material and/or a texture to it.
Open the Pie Chart editor and set the following parameters:
Set the following DataY values: 10,20,30,20,50,60,80,45,20.
Enable Keep Proportions.
Set Center Offset to 6.0.
Set Move Piece to 1.
Set Center and Height Offset to 20.0.
Enable Vertex and set different colors for all Color IDs.
