Viz Trio User Guide
Version 3.2 | Published June 29, 2021 ©
System Overview
Choose the best setup for your workflow:
System Overview - Basic Setup
Info: The system overview above shows a basic setup. A Viz Engine is typically used for local preview.
The Trio operator creates pages, most often from pre-made templates. A page is an instance of a template that can be customized with data values, like sports results or election data.
When the page is ready, the Trio operator can easily send pages with the necessary information to air.
Viz Trio automatically uses Media Sequencer to trigger final rendering of the output by the Viz Engine.
Note: Although Viz Trio, Media Sequencer and Viz Engine can be installed and operated on a single machine, they are mostly installed on separate servers for performance and security reasons.
Viz Trio can also interface with other systems for news feed and media resources, for instance MAM systems such as Viz One for video and media resources and Viz Pilot.
Social Media feeds and news can be interfaced and ingested in the workflow with the Viz Social TV solution.
System Overview - Advanced Setup
An advanced setup with newsroom and video integration involves several other Vizrt products such as a Vizrt MAM system, Viz Pilot, Viz Gateway and third-party systems such as a newsroom and database system.
Viz Gateway can be used to connect Viz Trio to most Newsroom systems using the MOS protocol.
Note: Viz Pilot can also be used as the control application. Viz Pilot also has a TCP/IP connection to the Oracle database.
