Viz Plug-ins User Guide
Text FX Size
images/download/thumbnails/95402179/ico_tfx_size.png
The Text FX Scale plug-in allows you to create a sizing animation of the characters.
Supported Pipelines
Classic Render Pipeline
images/s/-wjspee/8703/98yf4s/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
images/s/-wjspee/8703/98yf4s/_/images/icons/emoticons/error.svg
Text FX Size Properties
  • Begin: Sets the initial scale of the text before the effect.
  • End: Sets the final scale of the text after the effect.
