Viz Plug-ins User Guide
Text FX Emoticons
images/download/thumbnails/95402158/ico_emotico.png
The Text FX Emoticons plug-in allows you to create an emoticon container, add it to the Emoticons plug-in and replace characters (tokens) in a text string with an assigned container.
Supported Pipelines
Classic Render Pipeline
images/s/-wjspee/8703/98yf4s/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
images/s/-wjspee/8703/98yf4s/_/images/icons/emoticons/error.svg
Text FX Emoticons Properties
  • Autoscale: Scales the emoticon containers so their height above the baseline (0) is identical to the height of character A.
  • UTF-8 Encoding: Enables UTF-8 encoding for the text effect.
  • Token 1 - n: Sets the placeholder for an emoticon.
  • Container 1 - n: References the container holding the emoticon. The container should be similar to the layout of a glyph.
  • Precache 1-n:- Enables Viz Artist/Engine to cache the objects.
