Supported Systems
Note: As a general recommendation for all hardware types:
  • Disable all power saving options in Windows or in the BIOS Settings.
  • Disable Hibernate mode.
  • Disable Secure boot for driver installations (optional).
The installation of video, audio or graphics cards, is not required on a new system. However, for maintenance or upgrades, it is important to know how to install the different models.
All machines ordered from Vizrt are pre-installed and do not require any changes.
This section describes the all supported systems and their configuration supported by Viz Engine.
IMPORTANT! Any other setup than those described is not guaranteed to be supported by Vizrt and may cause problems during operation.
Note: Vizrt may make changes to specifications and product descriptions at any time, without notice.
