Gateway Administrator Guide
Version 5.0 | Published January 08, 2018 ©
Start, Stop and Restart Gateway buttons
Depending on the current run status you can use the buttons in the lower left corner of the interface to Start, Restart or Stop the Gateway.
When Gateway is running, the following buttons are visible and enabled:
images/download/attachments/29298155/userinterface_startrestart.png
When Gateway is stopped, the following button is visible and enabled:
images/download/attachments/29298155/userinterface_startgw.png
Starting Gateway
Start the Gateway Client when it is stopped.
  1. To Start Gateway, click Start
    images/download/attachments/29298155/userinterface_startgwbutton.png
  2. A message appears in the messages area confirming that Gateway has started
    images/download/attachments/29298155/userinterface_gwconfirmstart.png
Stopping Gateway
Stop the Gateway Client when it is running.
  1. To stop Gateway, click Stop
    images/download/attachments/29298155/userinterface_stopgateway.png
  2. A message appears in the messages area confirming that Gateway has stopped
    images/download/attachments/29298155/userinterface_stopconfirm.png
Restarting Gateway
Restart the Gateway client when it is running.
Note:
Refreshing the browser will not restart Gateway; it will only reload the page.
  1. Click Restart
  2. You will receive a message that Gateway is stopping, followed immediately by another message that Gateway is initializing again.
    images/download/attachments/29298155/userinterface_initialstop.png
    Tip:
    Please keep in mind that changing some Gateway configuration settings requires a restart in order for the changes to take effect.
