Gateway Administrator Guide
Version 5.0 | Published January 08, 2018 ©
Advanced Queuing (AQ) is not working properly.
An XML parser failure may be an indicator that the wrong AQ protocol is in use on the database.
Check if the Extended AQ is in use on the database. Gateway should detect if AQ is in use or not and set the correct parameters.
