Gateway Administrator Guide
Version 5.0 | Published January 08, 2018 ©
Gateway server is not running (Running status is red).
  • Check for error and warning messages in the log window.
  • Gateway will fail to start if another Gateway is running on the same computer, for example an old Gateway version 1.x.
    Note:
    A Gateway server must not be used by control stations as a regular Media Sequencer. If so the Media Sequencer will not run as a Gateway server. If this has been done, re-activate the Media Sequencer to run as a Gateway by clicking the “start” button.
