Gateway Administrator Guide
Version 5.0 | Published January 08, 2018 ©
Minimum Hardware Requirements
The following hardware components are required for the Gateway and Oracle Database Client. The requirements are separate, and only depicts the actual requirements needed to run each of the software installations.
  • Gateway
    • There are no specific hardware requirements for Gateway. The hardware required and network interface is depending on how many Newsroom Systems and clients that use the gateway. However, it is strongly recommended that Gateway is installed on its own computer or server. Sharing space with other resource-intensive systems, for example a database, is not recommended.
  • Oracle Database Client
    • Currently (for Oracle 11g) the requirements are listed as:
Oracle hardware requirements (11g)
Requirement
Minimum Value
Physical memory (RAM)
1 GB minimum
Virtual memory
Double the amount of RAM
Disk space
Total: 5.22 GB
Processor
AMD64 or Intel EM64T
Video adapter
256 colors
Screen Resolution
1024 X 768 minimum
IMPORTANT!
The values above are correct as of October 2017 and should be read as minimum required, please refer to the official Oracle Documentation at docs.oracle.com for updated information.
Note:
The Oracle database client is not necessary if you are connecting to Oracle via the Pilot Data Server.
