Gateway Administrator Guide
Version 5.0 | Published January 08, 2018 ©
Common sources of error
  • NCS and MOS ID’s are case-sensitive (check the newsroom system and Gateway).
  • Gateway must be restarted after configuration changes.
  • Software or hardware firewalls are blocking connections. Verify that the gateway has connections to all newsroom systems and control stations.
