Video Output: SHM Output
Configure Shared Memory Output channels from this panel. The shared memory output is only available on systems with non-IP Matrox video boards, or if Check Video Card is set to None in the Video Board section.
images/download/attachments/41803366/cfg_video_output_shm.png
  • Shared Memory Output: Sets the output mode for Shared Memory. Options are Active or Inactive.
  • Color Format: Displays the active color format for the configured SHM Output.
  • Unique Identifier: Changes the name of the Shared Memory if required. Used when connecting to services such as Viz Coder.
