SMPTE ST 2110-20/30/40 Configuration
The configuration of the IP settings was moved to an XML file containing IP relevant parameters only. The file ipconfig.xml can be found in %ProgramData%\Vizrt\Viz3.
Warning: When editing the XML file, do not delete any tags and only edit values between <tag> and </tag>.
SFP Settings
Setting
Description
IPv4Address
X.mio3: the static unicast IP v4 address used as source address and for the PTP connection.
X.mio5: the static IP v4 address used for the PTP connection, if DHCP is disabled. Can be 0.0.0.0 otherwise.
IPV4Gateway
X.mio3: the static IP v4 gateway address used as source address and for the PTP connection.
X.mio5: the static IP v4 gateway address used for the PTP connection, if DHCP is disabled. Can be 0.0.0.0 otherwise.
IPv4Netmask
X.mio3: the network subnet mask used for the source address and the PTP connection.
X.mio5: the network subnet mask used for the PTP connection, if DHCP is disabled. Can be 0.0.0.0 otherwise.
Smpte2059SfpSettings::DhcpEnable
X.mio5 only: enables DHCP support for the SFP unicast PTP settings.
Smpte2059SfpSettings::TypeOfServiceDSCP
Indicates that the Type of Service (ToS) is Differentiated Service Code Point (DSCP).
Range is [0..63] (6 bits).
Smpte2059SfpSettings::DelayMechanism
Indicates the type of delay mechanism to use for the time server connection.
0 = Invalid
1 = EndToEnd
2 = PeerToPeer
Smpte2059SfpSettings::IpMode
Indicates the type of internet protocol mode to use for the time server connection.
0 = Invalid
1 = Multicast
2 = Unicast
3 = Hybrid
Smpte2059SfpSettings::MasterClockDomainNumber
Indicates the time server clock domain number to use.
Smpte2059SfpSettings::JoinType
Indicates the type of membership request made.
0 = Invalid
1 = None
2 = IGMPv2
3 = IGMPv3
Smpte2059SfpSettings::IgmpV3Settings::FilterType
Only needed when the join type is set to 3 = IGMPv3. Indicates the filter type applied.
0 = Invalid
1 = Inclusion
2 = Exclusion
Smpte2059SfpSettings::IgmpV3Settings::FilterListCount
Indicates the number of IPv4 source addresses in the filter list. Maximum is four.
Indicates the list of IPv4 source addresses to filter separated by commas.
Important: The IP v4 settings for the source port on X.mio5 must be set in the Windows 10 network settings. If DHCP is not available on the essence network, static addresses must be used. Every SFP of an X.mio5 needs 2 unicast IPv4 adresses. One is for the PTP settings set in the ipconfig.xml, and the other is set in the Windows 10 network settings, used as source address (e.g. address used in an IGMPv3 environment for source specific multi-casting).
General Output Settings
Setting
Description
Redundancy
If set to true, enables the redundant stream for seamless reconstruction conforming to SMPTE ST 2022-7.
Video Output Settings
Setting
Description
EnableFlow
Set to true, to enable the flow at startup. This can be controlled using a command during run-time.
RtpPayloadId
Indicates the RTP (Real-time Transfer Protocol) payload ID.
TimeToLive
Indicates the time in which packets can be used in seconds. That is, it indicates the packets' Time to live (TTL).
TypeOfServiceDSCP
TypeOfServiceECN
Indicates that the Type of Service (ToS) is Explicit Congestion Notification (ECN).
Range is [0..3] (2 bits).
Primary::SrcUdpPort
Indicates the User Datagram Protocol (UDP) port of the sender (that is, transmitter).
Primary::DstAddress
Indicates the IPv4 address of the destination (that is, receiver). Only used in multicast.
Primary::DstUdpPort
Indicates the UDP port of the destination (that is, receiver).
Secondary::SrcUdpPort
Indicates the redundant stream UDP port of the sender (that is, transmitter).
Secondary::DstAddress
Indicates the redundant stream IPv4 address of the destination (that is, receiver). Only used in multicast.
Secondary::DstUdpPort
Indicates the redundant stream UDP port of the destination (that is, receiver).
Audio Output Settings
Setting
Description
EnableFlow
RtpPayloadId
TimeToLive
TypeOfServiceDSCP
TypeOfServiceECN
AudioPacketDuration
Indicates the outgoing audio packet duration.
1 = 125 µs
4 = 1 ms
All other values are not supported.
Primary::SrcUdpPort
Primary::DstAddress
Primary::DstUdpPort
Ancillary Data Output Settings
Setting
Description
EnableFlow
RtpPayloadId
TimeToLive
TypeOfServiceDSCP
TypeOfServiceECN
SMPTE352Payload
If set to 1, enables SMPTE 352 packets.
Primary::SrcUdpPort
Primary::DstAddress
Primary::DstUdpPort
General Input Settings
Setting
Description
Redundancy
JoinType
0 = Invalid
1 = None
2 = IGMPv2
3 = IGMPv3
Video Input Settings
Setting
Description
EnableFlow
RtpPayloadId
Primary::DstAddress
Indicates the reception multicast IPv4 address.
Primary::DstUdpPort
Indicates the reception User Datagram Protocol (UDP) port.
Primary::PacketIntervalThreshold
Indicates the threshold for generating the time interval between the IP packets alarm on the video flow.
The range is from 6.4 ns to 419424.0 ns in intervals of 6.4 ns.
Primary::IgmpV3Settings::FilterType
0 = Invalid
1 = Inclusion
2 = Exclusion
Primary::IgmpV3Settings::FilterListCount
Indicates the redundant stream reception multicast IPv4 address.
Indicates the redundant stream reception UDP port.
Secondary::PacketIntervalThreshold
Secondary::IgmpV3Settings::FilterType
0 = Invalid
1 = Inclusion
2 = Exclusion
Secondary::IgmpV3Settings::FilterListCount
Audio Input Settings
Setting
Description
EnableFlow
RtpPayloadId
AudioPacketDuration
1 = 125 µs
4 = 1 ms
Primary::DstAddress
Primary::DstUdpPort
Indicates the threshold for generating the time interval between the IP packets alarm on the audio flow.
The range is from 102.4 ns to 6710681.6 ns in intervals of 102.4 ns.
0 = Invalid
1 = Inclusion
2 = Exclusion
0 = Invalid
1 = Inclusion
2 = Exclusion
Ancillary Data Input Settings
Setting
Description
EnableFlow
RtpPayloadId
For SMPTE ST 2110 only: Indicates the RTP (Real-time Transfer Protocol) payload ID.
Primary::DstAddress
Primary::DstUdpPort
Indicates the threshold for generating the time interval between the IP packets alarm on the ancillary data flow.
The range is from 819.2 ns to 53685452.8 ns in intervals of 819.2 ns.
0 = Invalid
1 = Inclusion
2 = Exclusion
0 = Invalid
1 = Inclusion
2 = Exclusion
Change IP Properties
Although the IP properties may be changed by editing the configuration file directly, the IP address and port numbers can also be set via the command line interface. Because channel numbering is zero-based here, Output Channel 1 is referred to as VIDEOOUT_0. To check the currently configured values call the command using GET (instead of SET) without parameters.
To Change/Check the Destination Address and Port of the Output Channels
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*ENABLEDSTATE SET x
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTADDRESS SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTUDPPORT SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTADDRESS SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTUDPPORT SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTADDRESSKEY SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTUDPPORTKEY SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTADDRESSKEY SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTUDPPORTKEY SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTADDRESSAUDIO SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTUDPPORTAUDIO SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTADDRESSAUDIO SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTUDPPORTAUDIO SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTADDRESSANC SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTUDPPORTANC SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTADDRESSANC SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTUDPPORTANC SET xxxxx
To Change the Source Address of the Input Channels
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*ENABLEDSTATE SET x
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*DSTADDRESS SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*DSTUDPPORT SET xxxxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*REDUNDANCYDSTADDRESS SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*REDUNDANCYDSTUDPPORT SET xxxxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*DSTADDRESSAUDIO SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*DSTUDPPORTAUDIO SET xxxxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*REDUNDANCYDSTADDRESSAUDIO SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*REDUNDANCYDSTUDPPORTAUDIO SET xxxxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*DSTADDRESSANC SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*DSTUDPPORTANC SET xxxxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*REDUNDANCYDSTADDRESSANC SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*STREAMIN_x*REDUNDANCYDSTUDPPORTANC SET xxxxx
Viz Engine currently supports NMOS IS-04 and NMOS IS-05 protocols for IP enabled IO boards.
