Supported Software
Viz Engine Software
To run Viz Engine as a program or preview (optional) machine, the following software and configuration is needed:
Viz Engine specifications
Requirement
Software
  • Installation of latest Viz Engine/Artist package
  • Optional: (Additional plug-in packages like DataPool or Viz World Client)
  • Optional: Viz Engine must be installed with an MPEG-4 codec and Matroska splitter when used for local preview of video clips from Viz One
Codemeter runtime for WIBU based licensing
Hardware
License dongle for legacy hardlock licensing or valid Codemeter license
Supported GPU and videoboard
Executable(s)
viz.exe
Ports and Connections
  • 6100: Preview and playout
  • 14300: Viz Multiplexer
  • 50007-50010: Multiplexing
Network access
  • Optional: Mapped drive to VOS still store folder
Preview Server
The Preview Server option is used in situations where Viz Engine is used to provide frames for snapshot or thumbnail generation. A typical use case would be to connect multiple Newsroom Components to a preview server.
The Preview Server must be installed on a separate Viz Engine machine with its own license.
Requirement
Software
  • Latest Preview Server package
  • Microsoft .NET Framework 4
  • Latest Viz Artist/Engine package
  • Codemeter runtime for WIBU based licensing
Hardware
License dongle for legacy hardlock licensing or Codemeter license
Executable(s)
PreviewServer.exe
54000: Used to connect over HTTP with the REST interface.
Network access
Uses the ZeroConf protocol to announce available services.
Viz Artist Software
The Viz Artist design machine should preferably have the same specifications as the Viz Engine playout renderer, especially if the designers need to test performance issues on demanding scenes.
If designers are creating templates for Viz Pilot, it is recommended that Viz Pilot is installed on a separate machine for more accurate playout emulation on Viz Engine.
