HP Z8 G4
This section describes how to setup a HP Z8 G4 machine with the different cards provided by Vizrt. The HP Z8 G4 is a high performance workstation that can be configured with two CPUs, has 24 memory slots, multiple storage and PCIe configuration options.
More details about the HP Z8 can be found on HP’s website: HP Z8.
images/download/thumbnails/58358830/front.png images/download/attachments/58358830/hp_z8_open.png
Info: Only newer Matrox Boards like X.mio3 and DSX.LE4 are shipped with Z8 workstations. Older videoboards are not tested by Vizrt.
images/download/attachments/50601271/vcr_hpz8_p.png
PCI Configuration for Single GPU
Slot
Usage
Slot 1 – PCIe3 x8
Matrox AES Audio
G-Sync III
Blue Storm
Sea Level
Single Port Network Card
Slot 2 – PCIe3 x16
Graphics Card (Single / Dual Slot)
Slot 3 – PCIe3 x16
Used if Dual Slot GPU is installed
Slot 4 – PCIe3 x16
If one Graphic Card is installed, this slot is used for Video Cards (i.e. Matrox Video Boards)
Slot 5 – PCIe3 x4
Empty or can be used by Matrox AES Audio if Slot 1 is used
Slot 6 – PCIe3 x16
Empty
Slot 7 – PCIe3 x4
Empty
PCI Configuration for Single GPU with M264
Slot
Usage
Slot 1 – PCIe3 x8
Matrox AES Audio
Blue Storm
Sea Level
Slot 2 – PCIe3 x16
Empty
Slot 3 – PCIe3 x16
Primary Graphics Card (Single / Dual Slot)
Slot 4 – PCIe3 x16
Primary Graphics Card (Dual Slot)
Slot 5 – PCIe3 x4
Quadro Sync
Slot 6 – PCIe3 x16
M264
Slot 7 – PCIe3 x4
Empty
PCI Configuration for Dual GPU
Slot
Usage
Slot 1 – PCIe3 x8
Slot 2 – PCIe3 x16
Matrox AES Audio
G-Sync III
Blue Storm
Sea Level
Slot 3 – PCIe3 x16
Slot 4 – PCIe3 x16
Slot 5 – PCIe3 x4
Empty or used by Matrox AES Audio if Slot 2 is used by extension card (G-Sync, Blue Storm, etc.)
Slot 6 – PCIe3 x16
Secondary Graphics Card (Single / Dual Slot)
Slot 7 – PCIe3 x4
Secondary Graphics Card (Dual Slot)
Default Hardware
  • Tower 5RU
  • CPU: 2x Intel Xeon Silver 4114 (2.2GHz 10-Core)
  • RAM: 48 GB DDR 4 (6x 8GB)
  • SSD1: 256 GB S-ATA (Operating System)
  • SSD2: 512 GB M.2 NVMe (Data and Clips)
  • RAID Controller: Intel SATA/NVMe M.2
  • Power Supply: 1x 1125 W 90% Efficient
BIOS – Configuration
  • During Post, press F10 to access BIOS Setup.
  • Go back to Advanced Tab > Secure Boot Configuration.
    • Select: Legacy Support Disable and Secure Boot Enable.
  • Go back to Advanced Tab Overview.
    • Click on Build in Device.
  • Increase PCIe Idle Fan Speed to: 0050.
    • Click on Performance Options.
    • Set Intel Hyper Threading Technology to DISABLED.
  • Press ESC and save Configuration.
Info: Certain third party vendor drivers require secure boot to be disabled to install properly.
