HP Z440
This section describes how to setup a HP Z440 machine with the different cards provided by Vizrt. The HP Z440 (4U rack units) is a high performance single-CPU workstation with 8 memory slots, multiple storage and PCIe configuration options. More details about the HP Z440 can be found on HP’s website: HP Z440 Info.
images/download/attachments/44379066/hp_z440_gf.jpg
HP Z440 with NVIDIA K6000 card, Matrox X.mio2:
images/download/attachments/44379066/hp_z440_k6000x.jpg
HP Z440 PCI/PCIe Slot Layout and Usage
Slot ¤
Type
Used for
13
PCIe2 x1
AES Audio card (if the video card has it)
14
PCIe3 x16
Graphic card
15
PCIe2 x4
Unused/Free
16
PCIe3 x8
Video Card (Matrox, DVS or Bluefish)
17
PCIe3 x16
Radial Aerator, if needed, see note below
18
PCI 32/33
Unused/Free
Note: Radial Aerato is recommended for the X.mio2 and X.mio2 Plus boards. However, for video cards that have an onboard fan, such as the X.mio3, DSX LE 4, DVS Atomix or Bluefish Epoch 4K Supernova cards, this is not needed.
Z440 BIOS Settings
  • Advanced – Power Options – Fan Idle Mode
    • Default is two steps below maximum: **
    • Fan can be set to maximum, if temperatures are high.
Memory expansion
Memory expansions must follow the predefined fill-order and memory-type requirements. There is a table documenting the memory fill order inside the server cabinet. Refer to that table when adding memory modules. Memory configurations with more than four memory DIMMs installed, require the HP Z440 Memory Cooling Solution (AMO kit P/N J2R52AA). This fan can be obtained from Vizrt, or directly from HP.
