HP Z4 G4
This section describes how to setup a HP Z4 G machine with the different cards provided by Vizrt.
More details about the HP Z4 G4 can be found on HP’s website: HP Z4.
images/download/thumbnails/50601270/front.png images/download/attachments/50601270/open.png
Info: Only newer Matrox Boards like xMio3 and DSX.LE4 are shipped with Z4 G4 workstations. Older videoboards are not tested by Vizrt.
PCI Configuration
images/download/attachments/50601270/vcr_hpz4_p.png
Slot
Configuration
Slot 1
Graphics Card only! (Single / Dual Slot)
Slot 2
Used if Dual Slot GPU is installed
Slot 3
Possible Expansion Card Installation:
G-Sync
Blue Storm
Sea Level
Single Port Network Card
Video Cards (i.e. Matrox Video Boards)
Slot 4
Expansion Cards (see Slot 3, except Matrox Video Board)
Slot 5
Matrox AES Audio
Default Hardware
  • Tower 4RU
  • CPU Render: 1x Intel Xeon W-2102 (2.9GHz 4-Core)
  • CPU Control: 1x Intel Xeon W-2133 (3.6GHz 6-Core)
  • RAM Render: 32 GB DDR 4 (4x 8GB)
  • RAM Control: 16 GB DDR 4 (2x 8GB)
  • SSD1: 256 GB S-ATA (Operating System)
  • SSD2: 512 GB M.2 NVMe (Data and Clips, only in Render PC)
  • RAID Controller: Intel SATA/NVMe M.2
  • Power Supply: 1x 750W 90% Efficient
BIOS Configuration
  • During Post, press F10 to access BIOS Setup.
  • Click Advanced Tab > Boot.
    • Enable Fast Boot.
  • Go back to Advanced Tab > Secure Boot Configuration.
    • Select: Legacy Support Disable and Secure Boot Enable.
  • Go back to Advanced Tab Overview.
    • Click on Build in Device.
  • Increase PCIe Idle Fan Speed to: 0050.
  • Press ESC and save Configuration.
Info: Certain third party vendor drivers require secure boot to be disabled to install properly.
