BlueFish444 SD Lite Pro Express
images/download/attachments/41803523/vcr_bf4_board.png
BlueFish444 SD Lite Pro Express provides Fill, Key and GenLock connectors, and is the successor of the BlueFish444 Iridium|SD and the Digital Voodoo DeepBlue LT, that are no longer officially supported.
The card was mostly used with Viz Trio NV which basically was a system with the ability to run a Viz Trio client with local preview and video output on a single machine; hence, there was no video input or video playback support as with the Matrox X.mio Series. The local preview was able to render a different scene than the one being output on video. The card was typically seen on HP xw4600 workstations.
Connectors
images/download/attachments/41803523/vcr_bf4_connect.png
The BNC connectors from left to right are:
  • SDI Out A (Fill): SDI 4:2:2/4:4:4/Video
  • SDI Out B (Key): SDI 4:2:2/4:4:4/Video
  • Ref In: Analog GenLock input
Driver Installation
Use the driver version available on Vizrt’s FTP server to make sure of correct functionality and ringbuffer support.
Viz Artist/Engine Version
Driver
3.6.3
Bluefish444 v5.10.2.18
3.6.1
Bluefish444 v5.10.2.4
3.5.1
Bluefish444 v5.10.1.11
3.5
Bluefish444 v5.9.0.78
3.2.7
Bluefish444 v5.9.0.25
3.2.2
Bluefish444 v5.7.6
Note: Viz Engine 3.2.7 and 3.3.0 require the Bluefish444 v5.9.0.25 driver for all Digital Voodoo / Bluefish cards.
