Matrox X.mio5
The Matrox X.mio5 video board is the next generation IP card supporting SMPTE ST 2110-20/30/40 protocols. It is equipped with quad 25GbE SFPs delivering an effective, fully redundant bandwidth of 50GbE, capable of providing four UHD inputs and outputs.
images/download/attachments/54005999/Xmio5.png
Important: The final models of X.mio5 won't have a genlock connector. Cards must be sync'd to PTP.
General Notes
  • Please be aware that a xMIO5 uses a 16xPCI slot. It can't use the same slot as a xMio3.
  • To make sure the PTP is stable, all Power Management options in Windows and BIOS need to be disabled. ("runtime power management" disabled in BIOS settings)
  • xMIO5 boards require two IP adresses. This is mandatory.
images/jt-nm.org/images/jt-nm_tested_badge.png images/jt-nm.org/images/jt-nm_tested_NMOS-TR_badge_v2.png images/jt-nm.org/images/jt-nm_tested_2110_badge_v2.png
Viz Engine with xMIO5 is officially JT-NM Tested (April 2019) (https://jt-nm.org/jt-nm_tested/)
Key Features
  • Native SMPTE ST 2110 support with no CPU usage.
  • 4x UHDp60/50 inputs and outputs over 25GbE.
  • ST 2110-21 packet pacing in hardware for narrow senders (Type N).
  • Wide asynchronous receivers (Type A).
  • 32x HD inputs and outputs over 25GbE.
  • 256 audio flows from one to 64 tracks.
  • Multi-channel HDR conversion.
  • On-board de-interlacing, scaling and compositing.
  • Integrated hardware PTP for ST 2059-2.
  • Built in NMOS IS-04 and IS-05 support.
Matrox X.mio5 Configuration
Please see section SMPTE ST 2110-20/30/40 Configuration for further details.
