Overview and Connectors
The AJA Io 4K is typically used in combination with a suitable mobile workstation connected via Thunderbolt 2 interface.
Only the connectors SDI 1 - 4 and the Ref In connector are implemented for use in Viz Engine. For information on the connector mapping please see AJA Hardware.
Note: Connecting the device to a workstation with a Thunderbolt 3 interface using a Thunderbolt 3 to Thunderbolt 2 converter reduces the performance of the device.
