Wall
The wall object is a curved wall. The size and curving of the wall can be customized.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
Wall Properties
Use LOD: Enables/disables dynamic level of detail.
Height: Sets the height of the wall.
Width: Sets the width of the wall.
Depth: Sets the depth of the wall curving. The higher this value is set, the more curved the wall will show.
Angle: Sets the angle of the walls curving. Use this parameter together with Depth: To achieve the wanted curving of the wall.
Corners: Sets the number of internal corners the wall should be built up from.
Center: Sets the center axis of the object. Choose between Center, Bottom or Top.
Front: Lets you switch between front and back.
To Create a Wall
Create a new group and add the Wall plug-in to it.
Open the Wall editor and set the following parameters:
Set Height to 200.0.
Set Width to 400.0.
Set Depth to 400.0.
Set Center to Center.
Add a material and/or a texture to it.
Open the Transformation Editor and set Rotation Y to -45.0.
