Soft Mask
The Soft Mask plug-in applies a soft mask to an object (e.g. image or geometry).
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Soft Mask Properties
Progress: Move the mask perpendicular to the mask direction. Default is 0.0 and is based on the configured center position.
Rotation: Rotate the mask around the center.
Center X and Y: Define the X and Y position of the center the mask will have.
Gradient Width: Set the size of the gradient.
Invert: Invert the mask.
Mirror Gradient: Mirror the mask on both axis.
Blank: Offset the area that should not be affected by the mask.
Tracking: The progress can be controlled by a tracked Container to build the progress animation easier. Drag a Container to the drop zone.
